Buongiorno,
dove posso trovare una configurazione completa di tutti i parametri di Slic3r per la 3Drag?
Ho scaricato gli esempi (GCode) dal link seguente
http://3dprint.elettronicain.it/2012/09 ... li_stampa/
ma sono presenti solo alcuni parametri.
Parametri Slic3r
- Boris Landoni
Re: Parametri Slic3r
Ecco qua quelli che uso io (ogni tanto)
# generated by Slic3r 0.9.10b on Fri Oct 4 12:43:48 2013
avoid_crossing_perimeters =
bed_size = 200,200
bed_temperature = 50
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 80
brim_width = 0
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 1
duplicate = 1
duplicate_distance = 6
duplicate_grid = 1,1
end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors
external_perimeter_speed = 70%
external_perimeters_first = 0
extra_perimeters = 1
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 0
fan_always_on = 0
fan_below_layer_time = 30
filament_diameter = 3
fill_angle = 45
fill_density = 0.5
fill_pattern = rectilinear
first_layer_bed_temperature = 50
first_layer_extrusion_width = 0
first_layer_height = 0.3
first_layer_speed = 80%
first_layer_temperature = 195
g0 = 0
gap_fill_speed = 20
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed =
infill_speed = 60
layer_gcode =
layer_height = 0.2
max_fan_speed = 100
min_fan_speed = 40
min_print_speed = 10
min_skirt_length = 0
notes =
nozzle_diameter = 0.5
only_retract_when_crossing_perimeters = 0
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 40
perimeters = 2
post_process =
print_center = 100,100
raft_layers = 0
randomize_start = 1
resolution = 0
retract_before_travel = 1
retract_layer_change = 0
retract_length = 1.5
retract_length_toolchange = 3
retract_lift = 0
retract_restart_extra = 0
retract_speed = 40
rotate = 0
scale = 1
skirt_distance = 3
skirt_height = 1
skirts = 3
slowdown_below_layer_time = 5
small_perimeter_speed = 40
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0
solid_infill_speed = 60
spiral_vase =
start_gcode = G28 ; home all axes
support_material =
support_material_angle = 45
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_interface_layers = 0
support_material_pattern = rectilinear
support_material_spacing = 5
support_material_speed = 100
support_material_threshold = 45
temperature = 180
threads = 4
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 50
top_solid_layers = 3
travel_speed = 70
use_relative_e_distances = 0
vibration_limit = 0
wipe = 0
z_offset = 0
bed_size = 200,200
bridge_speed = 80
brim_width = 0
cooling = 1
duplicate = 1
extrusion_axis = E
extrusion_width = 0
fan_always_on = 0
fill_angle = 45
fill_density = 0.5
g0 = 0
gap_fill_speed = 20
gcode_arcs = 0
gcode_comments = 0
infill_extruder = 1
infill_first = 0
infill_speed = 60
layer_gcode =
layer_height = 0.2
max_fan_speed = 100
min_fan_speed = 40
notes =
perimeters = 2
post_process =
raft_layers = 0
randomize_start = 1
resolution = 0
retract_lift = 0
retract_speed = 40
rotate = 0
scale = 1
skirt_distance = 3
skirt_height = 1
skirts = 3
spiral_vase =
support_material =
temperature = 180
threads = 4
toolchange_gcode =
travel_speed = 70
vibration_limit = 0
wipe = 0
z_offset = 0
